Tomzwheels Chrome Z06
Old 10-23-2006, 01:56 PM
TomZwheels's Avatar
Default Tomzwheels Chrome Z06
Limited time special on Chrome Z06 Wheels. Give us a call at 1-866-939-1030 if you have any questions or if you would like to place an order.
4 17x9.5 Chrome Z06 $539
2 17x9.5 and 2 17x8.5 $539
4 18x9.5 $579
2 18x9.5 2 18x10.5 $579
2 17x9.5 2 18x10.5 $579
2 17x8.5 2 18x9.5 $579
Lugs:
Standard lugs $10.00
Standard Lugs with Locks $15.00
Lifetime Lugs from Gorilla $25.00
Lifetime Lugs with Locks from Gorilla $30.00
Thanks
Tom
Old 11-03-2006, 04:01 PM
02blackws6bolton's Avatar
What Is The Biggest Tire I Can Fit On An 18x9.5 On An 02 Ws6 Trans Am I Want To Keep The Same Size On All 4 Tires I Was Thinking 295/35/18 Will These Rub In The Front With A Stock Suspension Or Do I Need To Go To A 285/35/18 Thanks
Old 11-08-2006, 10:29 AM
TomZwheels's Avatar
Honestly I am not sure if the 295 will have any rubbing issues or not but I would suggest the 285 on the 9.5" wheel.
TC
Tomzwheels
Old 11-08-2006, 10:41 AM
BIG_MIKE2005's Avatar
285 really??
I was told not over a 275 on my stock 9.5 WS6 wheels
Old 11-10-2006, 09:59 AM
TomZwheels's Avatar
Originally Posted by BIG_MIKE2005
285 really??
That is probably because that was the stock size tire. Also depending on what tire you go with also is going to determine the size. For one example the Nittos usually run a little narrower than the BFGs, so in that case you could run the 285 Nitto on the 9.5 and shouldn't have any problems. But that is just from my experience here at our shop.
TC
Tomzwheels
