cleaning polished aluminum
Old 03-10-2007, 10:45 PM
formula001's Avatar
Default cleaning polished aluminum
Just wondering the process every body uses to clean their polished wheels. What is a good product to take out small water spots? I use a mothers polish but it does not seem to take the water spots out after alot of hand buffing. Is it ok to apply a wax to the wheels after polishing will that help keep them clean alittle bit longer. Just post up your methods. Thanks alot.
Old 03-10-2007, 10:55 PM
TR GTO's Avatar
Water spots are usually damaged and the only way to remove it is to tear the aluminum down to that level, just under the damage and the Mother's polish isn't going to do it on its own. You could try one of their powerballs with a drill and see if that's aggressive enough to kill the waterspots. Scratch Remover is aggressive enough for it, but it's not recommended on unpainted surfaces.
Old 03-11-2007, 12:38 AM
Mi11z's Avatar
mothers polish w/thier buffing ball
Old 03-11-2007, 12:14 PM
formula001's Avatar
Alright I will have to get the ball I guess, does it work ok on a cordless drill or Will it need some more RPMs behind it and use a power drill?
Old 03-11-2007, 12:17 PM
TR GTO's Avatar
Any drill should to the trick.
Old 03-11-2007, 07:37 PM
02SOMLS1WS6's Avatar
TTT. Does anyone else have a method they use to clean their polished wheels or different product you prefer.
