tire rotation and psi question
Old 03-29-2007, 07:50 PM
HIZPANICGUY21's Avatar
Default tire rotation and psi question
i have a 97 z28..running 245 35 zr19's...ive had them for about 3k miles now..i was wondering when should i rotate them (miles wise)?and if i should get an allignment right away and/or get them balanced again... and also what psi should i run them...thanks guys
Old 03-29-2007, 09:01 PM
NewYork Art's Avatar
I thought I read something about NOT rotating your tires...something with balancing and wear ride handling......Look at it this way,,your going to buy 4 new ones when you need them. I always tried to rotate them to even the tread wear and well it never really worked ,,besides flats are always messing things up cause you'll always be looking to put that one bad tires on the backside some where. I just ride on them till i think I need some rubber and buy 4 more.
Old 03-30-2007, 12:33 AM
true, but i want them to last me as long as possilbe..you know..anyone else???
Old 03-30-2007, 01:25 AM
MannyZ28's Avatar
GM says every second oil change...that'd be every 6k miles.
Old 03-30-2007, 11:21 AM
Thats A Good Idea..anyone Can Remember That..thanks..now What Psi Should I Run My Tires At?anyone?
Old 03-31-2007, 11:34 AM
MannyZ28's Avatar
Generally accepted rule for F-bodies is 30 psi, but that varies from tire to tire. Depending on what brand tire you buy, you can call the manufacturer, tell them what car you have, and they will suggest a proper air pressure to you.
