Can you confirm this spacer question?
Car=2002 SS
Is it true that the largest spacer you can use without changing the wheel bolts is a 1/2" spacer? If not, what is the largest one you can use?
This is for the FRONT wheels...not the back. I did a search on this and it never said if it was for the front or the back.
Thanks!!!
Thanks!!!
I read that even with a 5/16 spacer in front the amount of thread from the lug onto the stud is marginal and longer studs are recommended. But I havent done it yet. Hope someone with first hand knowledge jumps in.
