gsd3 or nittos dr
BMW ///M Nerd
Two very different tires. The GSD3s hook up good for a performance radial.
But a heated up Nitto DR is going to hook up better bar none.
Downfall is the softer sidewall for cornering, and high speed driving.
Is your car a daily driven street car? How often are you caught in the rain? You do a lot of street racing from a roll, or normally from a dig? Under 350rwhp?
BMW ///M Nerd
Sent you a PM back TX.
Rev, the Nittos are still stickier even without a burnout. Just normal driving gets them hot enough to stick just fine on the street. I've never driven on them with a stall, but I still say you would be fine. They are nowhere near as sticky as the MTs you have in your sig though...
The GSD3s are the better daily driver tire for sure. They hook pretty good, especially if your still under 350-360rwhp. You should have no problems with traction. You're even better off with an auto.
Pontiacerator
Thanks. I used Nittos on the street last spring through fall and MT's at the track. I'm trying to decide what to get for a summer tire this year: Nitto's again, GS-D3's, G-Force Sports, KDW's, etc. ...
I could get my Nitto's to hold if I eased it out from a dig and was careful. I'd rather not use them again, but from what you and others have said, they're going to stick better than any street tire.
Ive had them both. Like mentioned earlier, nitto's will hook better when they are warmed up. The GSD3's are a better "all-around" tire however, they have better traction, they last MUCH longer, and they are one of the best on wet roads (from my experience). You just need to decide what is more important to you. Do you want a better all-around tire, or do you want a better straight-line-traction tire?
