narrowed rear, 5.5'' b.s.
i was wondering if anyone out there was running a rear narrowed 2.5'' and a wheel with 5.5 b.s.? i just wanna make sure everything is gonna tuck nicely and look clean. i'm gonna be running a 325/50/15 on a 10'' wheel.
thanks guys,
-Jed
thanks guys,
-Jed
LS1Tech Co-Founder
If you narrowed 2.5 per side, you will need a 5.0 backspace. I had a previous Formula rearend narrowed 2.0 inches per side, ran a 5.5 backspace on a 10" wheel. Pics here: http://www.fquick.com/garages/Pontia...mula/1998/298/
28x10.5 drag slicks on the car.
The guy with the bright green metallic single turbo ta has 325's, narrowed 3 inches each side with ~5.5 Backspacing.
https://ls1tech.com/forums/drag-racing-tech/634153-s60-narrowed-weld-prostars-w-mt-325-50-s-pic-s.html
LS1TECH Sponsor
While a 2" narrow/side with a 5.5" BS is common, some would like the wheels to set in farther (like me) to get the car lower. I recently had a conversation with Gator about this exact subject. If you do not mind extra cutting, you can run 2.5" to 3" narrowed per side with a 5.5" BS. It all depends on what you are trying to achieve. Happy cutting.
