Will OEM C6 Z06 wheels fit on my C5?
LS1TECH Sponsor
Ok I am sure this has been discussed before. I could not find the answer though. I am interested in the OEM wheels/tires because I believe they will be a bit lighter than aftermarket replicas. I believe they may stick out a bit in the rear but its for a road race application so no big deal. Rub inside? any pics? whos doneit before? any input I do appreciate. Thank you all and God Bless
Jeremy Formato
Jeremy Formato
LS1TECH Sponsor
Thank you for the reply. I was begining tothink no one would touch this one. I have some spacers but how big? Also Am I correct to assume that the STK wheels are light than 99% of replicas?
Thank you, and Happy easter!
Jeremy
Jeremy
The fronts will fit without a spacer. The rears will need one. Some one claims to have had a spacer custom made, but I used a hubcentric bolt on adapter, 1.25 inches wide. Weights on the Oem wheels are 21.5 lbs for the front 18X8.5 and 23.5 lbs for the rear 19X10.
