Need Your Help,Which Tire?
just purchesed new wheels 18x9.5 front,18x11 rear, for Z06 -550rwhp need to make dission on tires,not sure what to use,NITTO RII 285/35/18 front ,305/35/18 rear or BF Goodrich T/A KDE-2 265/35/18 front,295/35/18 rear,mostly street driving and want to do some track,both drag and road course,what tires would you use,thanks
if your doing both i would fo with the RII, because of your choices, the wider tire is gonna hug the ground more than the 265. the RII is basically the same thing as the nitto drag only difference is the sidewall stifness. its harder on the RII
