255x50x16 vs 245x50x16 tire?
What is going to be the difference in using the 255 instead of the stock tire 245 size on the camaro? Does that make is a taller tire and how can I figure how much taller if so? There is limited clearance on the front when you make sharp turns with the 245 how will the 255's work?
