Need tire help on a non lsx vehicle
Old 04-16-2007, 05:26 PM
MonsterZ28's Avatar
Default Need tire help on a non lsx vehicle
I have an 03 F-350 4x4 and I'm trying to figure out if i can put on 20x10 mickey thompson classic 2's , and what size tire will fit on there with it being stock height.
I posted in performance trucks but had no luck,
I know its not an F-body but most of you guys have DD's that aren't so i was hopin someone could help me out,
Thanks,
Old 04-16-2007, 07:05 PM
Tally TransAm's Avatar
yes you can run 20x10s no problem
run a 305/55/20 nitto terra grappler or toyo open country at as they will fit the wheels and truck nicely and are both 10ply load range E tires so they will handle all the weight you throw at them
Old 04-16-2007, 07:08 PM
LS69TA's Avatar
You might be able to go as big as a 33x12.50, but a 305 should fit pretty easily.
Old 04-16-2007, 08:11 PM
MonsterZ28's Avatar
Thanks guys, i like how the fords wheel wells are gigantic compared to chevy's, so i can get a big tire under there, i dont want to lift it cause it's gotta tow a decent amount of weight so i dont wanna make it strain
Old 04-16-2007, 09:25 PM
uh. . . .
a 305/55/20 measures out to 33x1250x20
Old 04-16-2007, 11:27 PM
SSilverSSurfer's Avatar
^^^^this is true, 305/55/20 shoudl fit nicely, ive put 35x12.50x20 on the F250 depending on offsets of the wheels they might rub a little but its possible
Old 04-17-2007, 04:51 PM
MonsterZ28's Avatar
what offset would i need? will the mickey thompson classic 2's work
