tire question??
ok, well i guess i should give you a serious answer. A 275/55/17 has a diameter of 29 inches or so....its a truck tire. You might wanna try a 275/40/17 instead (25.5 inch diameter)
If youre asking about if you can run a 275 wide tire, it should be what tire came stock. but if it came with 245's then the most you should run is a 255.
Hope that clears it up
