Thoughts on this set up plz
Goodyear Eagle F1 Supercar for the 295/35-18. Goodyear Eagle F1 GS-D3 for the 275/40-17
Im guessing they are directional tires so I wont be able to rotate my tires with the set up.
I couldnt tell from the pictures.. but are the supercars as wide as the gs-d3's?
They are goin on the tomzwheel oe black motorsports z06 rims 17x9.5 fronts and 18x10.5 rears.
Will I have any fitment issues that I should let the tire guys know about.. in case they havent banged around on some fbodys hehe.
thanks
thanks
supercars arent as wide(if they were the same size) you wouldnt be able to rotate them front to back anyway, you can do side to side but youd have to dismount and flip the GSD3's. why are you doing two different style goodyear F1's?
I dont know It was the package deal offered from tomzwheelz. I initially thought it was a bit wierd, but then this is the first time I will be using different size rims and tires so wasnt sure if it would matter or not. Wasnt sure if other peopel did the same thing or not. Hence my post here hoping for some input before I order them hehe
