Anyone with 18x11 rear wheel please help with offs
Old 04-27-2003, 10:49 AM
Win
Win's Avatar
Default Anyone with 18x11 rear wheel please help with offs
I am ready to place an order for 18 inch HRE wheels, but have no clue as to which offset i should use for the rear. I want to run 315's in the back. Right now I have 285/35/18 on Y2K C5 wheels and an 1 1/4 drop in rear (had a little rubbing, but fixed it)
If anyone has 18x11 with or with out a lower suspension please tell me what offset you used, and how much rubbing did you have to contend with?
Old 04-27-2003, 11:28 AM
SS LS1's Avatar
Default Re: Anyone with 18x11 rear wheel please help with offs
What tire do you plan on running? Not much to choose from in 18" that are 315 wide and not over 27" tall.
As far as offsets go most people with 17x11" us a +50mm offset so that is what I would recommed. The 18's will fit the same if you use a 315 tire with the same 25.7" OD as the 315/35/17's everyone is running.
Greg
Old 04-28-2003, 09:01 AM
Xsta Z 28's Avatar
Moving to 'Wheels and Tires'
BTW, I have 18" x 10.5" Fikse with a 38 mm offset.
Quick Reply: Anyone with 18x11 rear wheel please help with offs
