ttII c5 brakes
Old 06-12-2007, 12:29 PM
greenherb's Avatar
Default ttII c5 brakes
so i have the c5 brake conversion using the lg motorsport bracket.... i would like a set of tt2 for the front 17 x 9.5...... i have read conflicting posts about fitment.... will this wheel fit.... what backspacing do i need... do i need spacers
Old 06-12-2007, 07:39 PM
StylesMcKnob's Avatar
I wondered about this as well...
Old 06-13-2007, 08:58 AM
greenherb's Avatar
ttt....
Old 06-13-2007, 01:19 PM
99SS'Vert's Avatar
I've got the TTII's 17x9.5's w/46mm and I'm running the Baer GT+ 13.2", which uses the same caliper as the Vette.
I think the Baer rotors might be little bigger than the Vette rotors are.
The only issure I've had with clearance is with using tape weights inside the wheel. The caliper scrubs them right back off.
Old 06-13-2007, 01:44 PM
1bdbrd's Avatar
How do you balance yours then? Hammer on weights on the inside lip?
As for the original question, do a search on my name for this topic in the Suspension and Brakes forum and you will find a thread with some good info in it about running this setup.
Old 06-13-2007, 06:25 PM
99SS'Vert's Avatar
No... the caliper doesn't displace that much area in regards to the rims width. They just have to move the weights a little closer to the inside of the wheel.
