Widening Wheels Responce To: hitemup9nine YOUR PM's ARE FULL!
Old 08-23-2007, 09:06 AM
Xsta Z 28's Avatar
Default Widening Wheels Responce To: hitemup9nine YOUR PM's ARE FULL!
Originally Posted by hitemup9nine
If I were to order the staggered ruff racing 278 wheels 18x8.5 and 18x9.5 and wanted to get the back two widened, Would that be possible. The back come with a 40+mm offset. They are for a ws6. Would I have any problems with them sticking out too much or looking funny. Thanks for your help
The wheels will not stick out, but, depending on how the wheel is widened the offset will change. The only way to widen a wheel without changing the offset is to put new material in equal widths to the front and back sides of the wheel.
If all the new material is added to the backside of the wheel (which is typical) the offset will change by 50% of the added width . . . So for example.
If you want the 9.5" wheel to be 10.5" wide, you are adding 1" to the back side of the wheel. 1" = 25.4 mm, 50% of 25.4 mm = 12.7 mm therefore the new offset of the wheel is 40 mm + 12.7 mm = 52.7 mm and that offset still fits on the car.
Old 08-23-2007, 10:53 AM
hitemup9nine's Avatar
Thanks I appreciate it
