275 tires?
275 tires?
I want to buy some 18" rims and put some 275 size tires on the rear with 245 on the front but i'm afraid it will look funny. Does anyone recommend or not recommend doing this?
Does anyone have any pictures of their car with this?
Any rims that would look good on my 01 f-body?
Thank you in advance for any input!
there is a pewter camaro with 17s half way down that has generally what your looking for at least to give you an idea.
https://ls1tech.com/forums/showthrea...ighlight=rebel
It depends on what look you want... if you got 245/40r18s on the front the overall diameter is 25.7 inches. You would want to run a 275/35r18 in the back to achieve the same sidewall height as the fronts, which is 25.6 inches(close enough). You would most likely want a 9inch wide rim because that would be able to fit both size tires on it with out the front tires looking too little for the rim.
