rim sz. will 19's fit good in the rear????
just wondering if anyone is running 19's in the rear and if so are there any issues with rubbing or what not??
thanks
thanks
Tire height and width are the deciding factor. Aim for a tire around 25.5 inches tall front and rear and you should be fine with a width of 275 or less. The max you could run without trial or error from my experience would be a 295 up to 26.5 in. tall rear and 275 at 25.5ish front.
I believe most run 245s front 275s rear or 275s all around. I hope that helps, sometimes im back at explaining things so you can PM me.
Use this: http://www.wallaceracing.com/tire-aspect-calc.php
If the tire fits what i said it will work.
I currently have 19x9.5 rears with 275/30/19 and there is plenty of room. in fact I am thinking of sending them out to get widened an inch for 305/30/19s
