What front tires to use with drag radials in the back?
Old 04-04-2008, 05:36 PM
98 Z28's Avatar
Default What front tires to use with drag radials in the back?
I'm looking into getting some Zr1 wheels 17x11 for the backs and wanted to use either M/T's 315's or the BFG drag radials but what front tire should I run with those tires? Thanks.
Old 04-04-2008, 05:49 PM
Mr. Luos's Avatar
I run Nitto DR's for the 17x11's.
I like my BFG KDW (1st style) on the fronts.
Old 04-04-2008, 06:00 PM
98 Z28's Avatar
So I would be ok going with bfg's like yours or some goodyear gs d3's for the fronts? I was just wondering because I was reading some where that If you mix tires it can be dangerous at the drag strip.
Old 04-04-2008, 06:01 PM
Mr. Luos's Avatar
As long as you have two radials...you should be fine.
But I will let someone that has a little better knowledge chime in.
