15x5 prostars in front?
I've heard both that they will fit and that they won't fit ... whats the real answer? This is a dd so I don't want to go with a 3.5 unless I truely have to. What b/s would be needed for the 15x5s? I do NOT want to use spacers. This is on a 2000 Z28. Thanks.
I personally could not get a 5" wheel to fit. I tried it with a .25 spacer, and it still didn't work. I don't believe Weld offered a wheel with the correct Backspacing either. For one, the backspacing was okay. The only thing that it hit on was the inner curve of the the wheel/caliper...I ground one of the calipers until I needed a new one...Still nothing.
