LS1 wheels on 93 Fbody with drum brakes
Old 05-30-2008, 08:34 PM
turbowhistle86's Avatar
Default LS1 wheels on 93 Fbody with drum brakes
My buddy tried a set of wheels off my 02 Z on his 93 V6 Camaro with drum brakes. he said that the rear wheels just barely don't fit, as in the center of the rim doesn't sit flush against the drum. Anyone else have this issue and can you just grind the outside of the drum flat or run very small wheel spacers?
Old 05-30-2008, 08:41 PM
Xsta Z 28's Avatar
Normal that the hub button doesn't fit. . . . either grind the edges of it down or ream the hole out a bit bigger.
