275 tire on a 8.5'' rim?
Old 07-16-2008, 05:36 PM
speedy33's Avatar
Question 275 tire on a 8.5'' rim?
can you fit a 275 tire on an 8.5'' rim?
thanks
speedy33
speedy33 is offline
Old 07-16-2008, 05:41 PM
Mr. Sandog's Avatar
thanks
speedy33
Depends on the tire. Each tire manufacturer will have a range of rim widths upon which you can safely mount each size/type of tire. You will have to go to the manufacturer's web sites to get this info.
Mr. Sandog is offline
Old 07-16-2008, 06:37 PM
NHRAMAN's Avatar
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Go 265.....
NHRAMAN is offline
Old 07-17-2008, 02:21 AM
99Bluz28's Avatar
Cool
FYI, the smallest recommended rim size for a 275mm tire is 9", at least in 275/40, 275/35, and 275/30.
But, I still would not recommend a 275 on a 8.5" rim. The tire manufactures list a minimum, and maximum wheel width for a good reason.
99Bluz28 is offline
Old 07-17-2008, 08:11 AM
Xsta Z 28's Avatar
245/45ZR17 iis the PERFECT tire for that rim . . .
And a 275/40ZR17 DOES NOT fit a 8.5" wide wheel. 9" minimum.
I just do not get it WHY force too big a tire on too small a wheel . . . it does absolutely NOTHING to improve traction . . .
Xsta Z 28 is offline
Quick Reply: 275 tire on a 8.5'' rim?
