Rear tires rubbing
Rear tires rubbing
I have an 01 T/A with MT 325X50X15 Et steet tires on a set of 15X10 pro stars with a 7.5 bs on the rear of my car and they stick out past the fenders a bit so every time i hit a bump the tires rub on the lip. I thought about getting the fenders rolled, but I don't know if that would do anything since the tires stick out past the fenders a bit. Any ideas?
if ur tires are sticking out then the rubbing must be directly on the tread. rolling fender wont help. either smaller width or try adj shocks for the rear so shock travel is limited. just keep in mind, adj. shocks will stiffen rear ride if set that way.....
