These fit?
These fit?
Wondering about the back spacing---for a 4th gen
http://edmonton.kijiji.ca/c-cars-veh...QAdIdZ71501056
Camaro & Firebird Fitments
Bolt Pattern
5 x 4.75" or 5 x 120.65 mm
Lug Nut Size
19 mm socket (6 sided socket preffered over 12 sided sockets) 3/4" will work in a pinch.
12 mm X 1.5 pitch commonly marketed as M12X1.5 - Recommend a "Bulge Cone Seat" style lug nut.
Wheel Fitments
The numbers in the columns are as follows:
WIDTH ..... OFFSET ......... WIDTH OF TIRE
Front and Rear
7.0" ..... +35 to +40 mm .... 215, 225, 235
7.5" ..... +35 to +45 mm .... 215, 225, 235
8.0" ..... +38 to +55 mm .... 225, 235, 245
8.5" ..... +38 to +45 mm .... 235, 245, 255
9.0" ..... +38 to +56 mm .... 255, 265, 275
9.5" ..... +38 to +56 mm .... 255, 265, 275, 285
10.0" ... +38 to +48 mm .... 265, 275, 285
REAR Only
10.0" ... +38 to +54 mm .... 275, 285, 295
10.5" ... +38 to +50 mm .... 285, 295, 305, 315
11.0" ... +45 to +56 mm .... 305, 315, 335
NOTE: 315 series tires DO NOT fit 9" or 9.5" wheels. It will not be discussed any thread posting will be edited, locked or deleted.
Bolt Pattern
Lug Nut Size
Wheel Fitments
Front and Rear
REAR Only
