10 Second Club Now you are haulin! 10s are sweet
10's on motor this time
Old Oct 1, 2013 | 11:08 AM
rpmauto's Avatar
Default 10's on motor this time
Well I finally had a chance to make it to the track this year. I made it once last year with the new 441 in the car. Didnt do very well. This time first pass off trailer was 10.991 @127. By far probably not what it should be for what I have in the car. But I am happy with it. I think with some better shifting, and a better 60' it should go 10.8's on motor. Then maybe i will turn on the spray again and see what she does. Went 10.70 a couple years ago on spray.
My daughter took my phone and made a vid of one of my passes in a bracket class. I had to load it on facebook as my phone would not let me e-mail it to myself. https://www.facebook.com/photo.php?v...type=2&theater
don't know for sure if that will work, but here is a pic of my slips. Pretty consistent for a stick car with kyb adj. shocks and not racing for a year.
ok for some reason it will not upload my pics now. I will try later.
Maybe this time I can figure out how to get the 10 sec club to appear by my name.
Old Oct 1, 2013 | 12:40 PM
red01camaroz28's Avatar
What were your 60' times? Just curious to see what you were able to do with the KYB AGX adjustable shocks? I had them on my car till the end of last year when I decided to put double adjustable Afco's on my car because I broke the rear end last October and decided to redo the whole rear suspension all at the same time. My best 60' with those shocks were a 1.502.
Old Oct 1, 2013 | 12:44 PM
rpmauto's Avatar
So far the best 60' has been a 1.54. I need to go to the track more and play with them,launch rpm, and shift rpm with the new motor. I ran 3 passes the other day with the exact same 60' of a 1.627 best was a 1.595. I get some pretty good wheel spin off the line. Went sideways on the 1-2 shift a couple times. But at least it was consistant
Old Oct 5, 2013 | 07:36 AM
rpmauto's Avatar
Car is full weight too. Scaled it and it surprised me a bit. Went right at 3500# without me. Im 225. I figured the car would be heavier. The only reduction has been spare, abs module, and k-member. I figured with the cage and all the other heavy suspension parts that it was around 3650 w/o me. Still a pig for racing though.
Old Oct 13, 2013 | 04:22 PM
rpmauto's Avatar
Went to Cordova and ran again yesterday. Track hooked a ton better. Ran a 10.933, then came out of the hole a bit harder and ran a 10.824 @127 with a 1.542 60'. Backed that up with a 10.856. Now i have got to powershift it to see what it does. But it will have to wait till next year. Racing is pretty much over hear till spring.
Old Oct 13, 2013 | 10:48 PM
19736.o's Avatar
Very nice
By Brett Foote | 2026-06-04 05:00:17
