New best
So the je pistons i bought are dished, but a little too much and i only end up at around 10.9-11.0:1 cr (same as stock ls2) and i'm now worried the lower CR might kill it too much with the cam i'm using which is a 243/250 .661/.652 108lsa with 30deg overlap. I didn't want to go bigger on the cam to lower the dcr as i still drive it on the street, and being that it's only a 6.0, i think the cam i'm using is already borderline.
I can go to a thinner 0.040 cometic and gain a little, but i'm just not confident in those head gaskets versus the gm mls and i don't really want to mill the heads either. I guess i will just have to run it as is and see what happens. Anyway that's why i was just wondering what your CR is. I'm guessing it has to be at least high 11's CR with milled 799's.
I didn't pick this cam it just came available and i bought it thinking i can use it something. I know it's a bit on the big side for a 6.0, but i've decided i'm going to try it first up, and if it doesn't work well i will remove it and fit something else.
It was a pain to get the CR i want all the shelf pistons, with the heads i have. I didn't want to custom order pistons but in hindsight i should have. The only good thing is i won't have to worry about pump gas not being good enough. Also i should be able to keep some good timing advance in it, which should help in theory.
Anyway, back to your car. I always like seeing people getting the most out of sbe. And the sbe's can sure take a beating more than most of us ever imagined. I even bought good aftermarket rods for my 6.0 that i'm building and i was going to use them, but i've now decided to stick with the stock gen4 rods in it this time around. After seeing what i've put my current gen3 5.7 through and it still won't die. I already had the je 6.0 pistons to suit stock rods also. I'll keep the other 6.125 rods i have, in case i ever need to use them.
I will think more about milling my heads. They are somewhat rare ecr nascar small bore ls7's, even if it's just in my head only, it kind of puts me off milling them. If i try it as is, if it doesn't work, i can change things around then. I haven't had enough experience personally with bigger cams in 6.0 ls's, and around 11:1 cr only.. i really don't know how it will work until i try it. In my mind a 243/250 with 30deg overlap is big, but not that huge, but maybe i'm totally wrong and it'll be a slug with 11:1 cr. Yours is working very well for what it is, with a bit smaller cam than i have.
I will keep you posted.
My valves are 2.10 / 1.55, and all titanium (which won't really gain any HP being lighter than stainless, except can use less spring pressure for longevity of springs/lifters)
I bought the heads as they are. I have no idea what they flow but they look impressive. If they work even just as good as a very good cathedral head, i'll be happy. Any more will be a bonus.
