10 Second Club Now you are haulin! 10s are sweet
I'm in the club
Old May 26, 2005 | 07:55 AM
LS1 BU's Avatar
Default I'm in the club
I'm not happy with my times but I'll post anyways
ET 10.61
1/4 MPH 125.6
60FT 1.51
1/8 mile timers were not working
This was on 26/1050/15 ET DRAGS. I had winodw switch a 6600 rpm and I was on the window switch at about 200 feet before finish. I'm going back to my 28/1050/15 ET DRAGS. I should be able to 60ft much better. Car only ran 11.55 at 115mph on motor. I'm pretty disappointed with the times. I'll list setup.
Stock bottom end
Stage one LS6 heads. stock valves
G5X-3 cam on 114 lobe sep.
Speed inc A4 with PT4000
ford 9 inch with 3.90 gears
usually run 28/1050/15 ET DRAGS. ( I tried 26/1050/15 to see if it would pick up on motor.
Nitrous pass was on a NX 150 shot.
Not happy with motor passes. Car didn't pick up anything with the smaller tire. Car made 428.8 rwhp and 390rwtq. Should run faster on motor. Weather wasn't great.
Old May 29, 2005 | 09:25 AM
02SOMWS6's Avatar
Why did you think you would pick up anything going to a 26" tire. I have 2 sets of 26"(ET-streets ET-drags) and can't wait for them to wear out so I can switch to a 28" tire. All the best times I have seen were done on a 28" tire or bigger. I know my best times will be when I switch to 28" tires
Old Jun 1, 2005 | 02:35 PM
LS1 BU's Avatar
I made peak power at 6500 rpm. With a 28 inch tire I was going thru the traps at only 5700 rpm. When I put the 26 inch tire on I was going thru the traps at 6100 rpm. I didn't pick up any ET.
Old Jun 2, 2005 | 05:17 AM
next's Avatar
Post up a time slip so I can update you.
Old Jun 2, 2005 | 09:16 AM
LS1 BU's Avatar
I'll try and get a pic of it.
Old Jun 2, 2005 | 04:41 PM
SuperZ's Avatar
good job man!
