hi-mid 10's possible?
here are mods.....
pro 5.0 shifter
spec stage 3 clutch
mccleoud adjustable master cylinder
01' slave cylinder
lightened flywheel
jett hot coated hooker longtubes
3" off road x pipe
dynomax bullet race mufflers
rear 02 simulators
suspension teniques lowering springs
underdrive pully
ls6 intake
all freebie mods!
smog delete
T.E.A stage II plus heads(3k dollars in these alone)
dissaembled,bead blasted,comp multi-angle valve job,cut for bigger springs,heads milled for about 11.1
comp cam 275/275 222/222 .566/.566 112l/s 3714/3714 hr 112
moser 9" 4.11 gear w/locker
Bmr torque arm
UMI lower control arms
subframe connectors
mickey thompson et street drags not radials.
car makes 420rwhp all motor and pulls 525+rwhp on 80 shot dry(would have been more but let off at 5400rpm's)
what do you think I can get all motor and what on the shot?
with all the folks on this site im sure im matching pretty well mods wise to quite a few.
thanks
