10 Second Club Now you are haulin! 10s are sweet
oh sooo close
Old Apr 23, 2006 | 08:01 PM
White2000TA's Avatar
Default oh sooo close
http://www.fast-ta.com/xvideos/402firstrace.wmv
Car has gone on a large diet and is being tuned a bit more.....
btw ignore the first two runs...
Old Apr 23, 2006 | 08:17 PM
GM Muscle's Avatar
Nice passes. Car left pretty hard on that last pass. Go on your diet, get that 60' down and you'll have an easy 10 second car.
Old Apr 24, 2006 | 07:38 PM
sleeperstyle's Avatar
try 11.009- THAT is close.
you being n/a i'd be willing to bet weather would get you well into the 10.90's.
good luck- SICK n/a times!
Old Apr 24, 2006 | 08:18 PM
OUCH!!!! 11.009 man i demand the calibration records The weather was good that day, but ive made the following mods since then: (I figure thats about ~100ish lbs off the front of the car. if that doesnt put me in the 10s.... I QUIT
Delete AC
Replace hood with VFN
strip carpet (will be replaced with lightweight)
Relocate battery
Replace stock seats with Kirky
install 6 point cage
Old Apr 24, 2006 | 10:33 PM
Abdullah's Avatar
what are your mods?
your mph should be higher? right? 123 mph is a little low, is your car an A4?
thanks.
Old Apr 25, 2006 | 12:02 AM
Originally Posted by Abdullah
what are your mods?
thanks.
Yeah its a A4 (th200-4r). Its a LS2 402 alum block with afr 225 heads + all th bolt ons. Not much left stock on this car. I just wanted to get in the 10s n/a.. then ill spray it to the 9s.
