10 Second Club Now you are haulin! 10s are sweet
Will this get me there?
Old Jan 4, 2007 | 11:45 AM
mhoglund's Avatar
Default Will this get me there?
I'm thinking of doing a Texas Speed 383 short block and using my current AFR 205's. I will probably use the same cam I'm running now. On top of that I will be using A Procharger D1SC. Right now I'm running mid to high 11's with my current setup.
What upgrades/options as far as rings, rods, pistons, and crank would I need if any?
Old Jan 4, 2007 | 12:36 PM
Ray@Nitrous Outlet
Guest
Posts: n/a
depending on traction, the car should make enough power to run 10's
