Another how fast will I go post!!
Engine- Stock shortblock, stock heads with Patriot dual springs, MS3 cam, LS6 intake, Jet-Hot LTs into 3" duals, ASP Pulley, SLP Lid, Ported Stock TB, MSD Wires. Put down 397rwhp and 365rwtq with tune.
Nitrous Kit- TNT Twister Force 2 kit jetted for 150rwhp, After tune 550RWHP and 550RWTQ.
Trans- T-56 with Spec Stage 3 clutch.
Susp.- QA1 R-Series 12way adj. fronts with 275lb springs, Rear QA1 coilovers 12way adj. with 150lb springs, Spohn adj. T/A set at -2* pinion angle, Spohn adj PHB, BMR LCA non adj., BMR SFC, No Front Swaybar, Spohn Drag rear swaybar.
Rearend- S60 with spool, lightweight axles, alum. cover, 4.30 gears, Chromoly Driveshaft.
Wheels and tires- Prostar Fronts 15X3.5 , 160R15 metric tires, Prostar rears with 28X10.5 ET Drags.
Raceweight- 3,250-3,300lbs is in the ballpark, And I can drive stick very well so you should factor that in. Lets see what you guys think.
Dan
Dan
Goodluck man! With your weight and power I think your goal is very possible!
-Jacob
