10 Second Club Now you are haulin! 10s are sweet
this must be annoying
Old Apr 15, 2008 | 05:21 PM
hndakilr's Avatar
Default this must be annoying
im not the type to post a thread like this but this is my actual setup that i just purchased.
i already have true duals, m6 98 firebird
i got the ms4, lt's, and nx 100 shot
im thinking more like mid-11's but i wanted to get some more opinions
thanks!
Old Apr 15, 2008 | 05:38 PM
LSGunZ28's Avatar
what gears do you have, what kind of tires are you running? and what typ of rearend?
and is that all you have? LTs and MS4? No intake? manifold? no catback?
state more specific stuff.
Old Apr 15, 2008 | 06:48 PM
hndakilr's Avatar
yeah i left some **** out
i have true duals, 4:10's, 555r's
stock intake
Old Apr 15, 2008 | 07:38 PM
RedsrtAk's Avatar
the stock 10 bolt is going to be a huge weakness on a M6....
Old Apr 15, 2008 | 09:15 PM
LSGunZ28's Avatar
you cannot cut good 60's on those Nittos , and with that power...
Look, I dunno if you are on your stock 10 bolt, but if you are, youre gonna need a stronger rearend, then after the stronger rearend you will need some good tires and get a great 60' in the 1.5s would be excellent and very possible with those gears and that cam, however you are limiting your power a lot going through a stock intake manifold, stock intake, stock TB, etc... a cam can breath its best when you have a full intake and exhaust... and some better than stock heads will help you more...
also we need to know your weight
tell us this...
Your complete list of mods. everything, suspension, etc...
your rearend if its a 10 bolt or something else, I know its 4.10s
your cars weight
ALL of your mods again:
so far I know you have LTs and true duals and 4.10s and MS4 and nitrous...
Now considering you ONLY have the MS4, LTs and True duals, lets say you have cats and theyre costing you a few hp, lets say you cant get a good 60' due to your nittos and lets say all of your intake is completely stock.... with the 100 shot you may be able to break in the 10s, even witha sorry 60'... However. I can bet your *** that just with slicks, and s rearend to hold the shock, and just a better intake you can run 10.99s as well without the nitrous...
