11 Second Club Snake eyes are a good thing
Am i good?
Old Jan 28, 2010 | 09:11 AM
blubyu02's Avatar
Default Am i good?
2000 z28 m6 mods are,
ls6 intake
23x/23x cam all supporting mods
untouched 853's besides the springs
full bolt ons
ls7 clutch
moser 9inch full spool
16'' mt et streets
150 shot
im hoping to run 11xxx on motor and 10.99 or better on spray is that possible? i have no weight reduction besides spare tire, jack and all that egr air stuff. other than that i daily drive the car i just want an 11xxx motor pass any input/suggestions would be appreciated thanks
Old Jan 28, 2010 | 09:13 AM
j_dover's Avatar
yea but that moser 9 inch is no good ill give u 10 bolt for it lol
Old Jan 28, 2010 | 09:28 AM
blubyu02's Avatar
i know man, it squeeks and chirps when i turn but for like 1800 and your ten you can get it haha and you can be the one squeeking and chirping
Old Jan 28, 2010 | 09:30 AM
01SS99red's Avatar
you should be right around 11.8XX on motor with that set up if you strip it down some could go 11.6XX on motor
Old Jan 28, 2010 | 10:05 AM
blubyu02's Avatar
no stripping for me its my daily for now, plus i like all the ammenities, i thought about a slick/skinny set-up but i just spend all my mod money on that rear-end so that will have to wait for a looong time lol.
Old Jan 28, 2010 | 09:42 PM
Carter01's Avatar
ls6 intake
full bolt ons
ls7 clutch
16'' mt et streets
150 shot
Almost my exact setup but I have more weight reduction, 3450 with me in the car. 11.75 with a 1.75 60ft so far, my car picks up 1.5 in the quarter for every tenth I pick up in the 60. If i can bust a 1.55 60ft I should run 11.40s on slciks, hopefully 10.50s or so on Nitrous. I will tell you good luck with the 6sp and the Mt Et Streets, my best 60ft has been a 1.69, they just don't hold the shock of the 6sp very well when launching above 5500. Good Luck
Old Feb 1, 2010 | 08:48 PM
blubyu02's Avatar
i got such a good deal on the radials i couldnt let em go, im going to buy some et streets after i wear these out and some lightweight fronts. i just want 11's on motor and 10.99 on the 150 shot i can taste it lol
Old Feb 4, 2010 | 09:45 AM
blue98Z's Avatar
I pretty much run the same setup as you do except I was running on a 26x11.5x15 ET, Spec 3, 228/230. Best on a 90*+ day was 11.81 w/1.58 60ft with my M6. The shot should get you pretty damn close if not in the high 10's though. Good luck to ya bro.
Old Feb 6, 2010 | 08:49 PM
outtacontrolz28's Avatar
You will be in the mid-high 11's easly
I have a MS4/Fast92-92/Yank 4k stall/12 bolt with 3.73s/ stock ls1 heads and stock bottom end and full weight..I went 11.43@119
So it is defenitly doable with your setup..best of luck
