Happy Days
) with help from Ed Hutchings from VA with tune, finally
11.94 @ 114
More to come on next test day in August as he has found other faults in tune on fuel side since this run. It was running 13.95ish AFR at WOT creating 2-3* KR as well.
And best of all it idles like a dream.
Other problem on all 3 runs was it shifts at about 5700 1-2 shift when its set at 6200. 2-3 is about 6100 which is ok.
I see you have same SS3600, what rpm do you launch at? I have been leaving off idle so far
since found a faulty TPS, which was showing peaks and troughs in log from 100% down to 47% without me lifting. fitted new one, now idle has gone crazy!! time for Ed to work his magic again.
