11 Second Club Snake eyes are a good thing
11.80s possible?
Old May 6, 2014 | 08:24 AM
mayham711's Avatar
Default 11.80s possible?
going to the track for the first time this weekend really wanting to break into the 11s.
s10 that weighs 3000 with no driver, bored 5.3, carburated with dual plane intake, .598"/.596" 239/233 cam, double valve springs, titanium retainers, 241 heads, flat top pistons, brp 1 7/8 lt headers th400 with good shift kit, tci 4000 stall, 2 step, 8.8 rear end with posi and 3.73 gear, 90/10 drag shocks on front and 9 way adjustable shocks on the back, i also have 8.5x26 m/t slicks.
Old May 6, 2014 | 08:50 PM
BODUKE's Avatar
If you can drive and can get traction you should hit that number.
Old May 7, 2014 | 10:12 AM
thunderstruck507's Avatar
at that weight with the setup you are running you should be beyond your goal even if the driver weighed 500lbs if the tune is dialed in well
Old May 7, 2014 | 10:16 AM
senicalj4579's Avatar
I would think so. Hook it up well and you should have it.
Old May 7, 2014 | 10:23 AM
handyandy496's Avatar
You have it all if its well tuned. At what rpm are you shifting?
Old May 8, 2014 | 07:41 AM
mayham711's Avatar
shift light comes on at 5700, rev at 6300. what should it be? timing at 32 degrees comes in a 2800 rpm. sound about right? I have a well knowledgeable guy going with me.
Old May 8, 2014 | 09:19 AM
Do you have a dyno sheet? You will want to shift a few hundred RPM past where it makes peak HP. It's a balance of keeping it at the highest average HP. Ideally you wouldn't want to shift until power has fallen off to a lower point than where it will end up in the power band once the shift occurs.
Mine peaks at ~6300rpm but likes to be shifted around 6700rpm...might like more but that's as high as I want to spin it.
Old May 8, 2014 | 09:27 AM
mayham711's Avatar
I haven't got to dyno it yet. but id figured ill turn it a little harder than I do on the street. might mix some c16 gas in it so I can run more timing, will that help?
Old May 8, 2014 | 09:30 AM
speedtigger's Avatar
Old School Heavy
I think you have your goal covered no problem. However, you are going to want to shift that thing higher. I am guessing 6400 RPM with a your rev limiter at 6800.
Old May 8, 2014 | 09:55 AM
mayham711's Avatar
I figured with that short of a tire on the back and my 3.73 gear it will be like having a 4.10 gear and probably will go through the lights around 6400?
Old May 8, 2014 | 10:00 AM
Old School Heavy
Depends on what speed you go through at. According to the calculator with 7% converter slip 114 MPH is about 5900 RPM
http://www.hotrodpitstop.com/tool.php#0
Old May 11, 2014 | 06:32 PM
mayham711's Avatar
best run I got last night was a 8.06 (1/8 mile track). converting it to 1/4 mile time its a 12.65. truck was really rich all night. it needs a smaller carb and a 4.10 gear. i went through the lights last night in 2nd gear and only at about 6500 rpm lol.
Old May 11, 2014 | 06:37 PM
Old School Heavy
What carb do you have?
Old May 11, 2014 | 06:42 PM
mayham711's Avatar
800 Holley. I'm putting a 750hp on it soon
Old May 11, 2014 | 07:13 PM
Old School Heavy
Why the carb change?
Old May 11, 2014 | 07:30 PM
mayham711's Avatar
We already have it jetted down a lot. We have a 750hp I can try for free. I think it will be faster.
Old May 11, 2014 | 07:34 PM
Old School Heavy
It may be, but I just want to share that the size does not dictate the a/f ratio.
Old May 11, 2014 | 07:55 PM
mayham711's Avatar
true. but we have a 68 jet in the front now. still black. 750 or 700 should be in the right direction.
Old May 25, 2014 | 08:52 PM
mayham711's Avatar
well i made it in the 11s.... kinda.. 7.62, 11.96 converting it to 1/4. im thinking the mph and 60ft it kind of slow.
1.715 60f
4.894 330ft
7.62 660ft @ 89.82 mph
