11 Second Club Snake eyes are a good thing
Help getting at 10.99
Old Jul 27, 2014 | 08:40 PM
021le's Avatar
Default Help getting at 10.99
2002 NBM 1le z28 a4
hardtop 22k+ miles
Here are the current mods.
Yank 4000 RPM stall converter
trans cooler
HD2 shift kit
233/236 custom cam
upgrade springs/ pushrods
aftermarket oil pump
custom dyno tune (429hp MD Dyno)
Hooker long tube headers
Underdrive crank pulley
egr/air delete
MSD wires
Becool Radiator 160 stat
Intake lid with K&N air filter
Lanes true dual 3in exhaust with twister mufflers
Dr. Gas X pipe
Auburn locking rear end with 4:10 Richmond gears T/A cover
QA1R front coil over 275# springs
removed front sway bar
Pa racing turbo k-member
QA1 rear shocks
Drag bags in rear springs (never air em up/use em)
MWC front and rear bumper supports
removed rear seat and belts
Subframe connectors
weld rt-s 15/10 with 275/50-15 Hoosier drag radials rear
weld rt-s 17/4.5 with m&h radials up front
anything not listed is how it came from the factory
3400# race weight
best time so far
this april with mt drag radials
da 144ft 54deg
1.53 60ft
7.07 1/8th
96.19 mph
11.10 et
120.45 mph
tires set at 20 psi.
latest time last week in the heat with new hoosier drag radials.
da 1479ft 70deg
1.52 60ft
7.10 1/8th
95.32 mph
11.16 et
119.63 mph
tires set at 16 psi.
wanting to go 10.99
any tips? or free mods?
I think once is cools off I can get my slip
Old Jul 27, 2014 | 08:42 PM
Mean87SS's Avatar
chrs1313 ram air?
Old Jul 28, 2014 | 01:17 AM
tyler ovel's Avatar
Take some more weight out, your almost there.
Old Jul 28, 2014 | 09:34 AM
021le's Avatar
anything you recommend that is ez.
want interior stock appearing, gotta have my stereo and a/c. anything else can go.
Old Aug 3, 2014 | 09:17 PM
senicalj4579's Avatar
Mine went 10.9 with same mods in sig except it had a ss3600 then. You should have it in better DA. A good CAI might get you there in the same DA.
Old Aug 24, 2014 | 12:30 PM
021le's Avatar
Update
11:00 pm
temperature = 86f
45%humidity
29.92 in pressure
DA=+2594 ft
Relative Density: 92.63 %
1.5124 60ft
7.0315 1/8th
96.32 mph
11.0646 et
120.74 mph
tires set at 18 psi.
getting closer
Old Aug 24, 2014 | 05:47 PM
JOHNNY59's Avatar
Originally Posted by 021le
2002 NBM 1le z28 a4
hardtop 22k+ miles
trans cooler
HD2 shift kit
233/236 custom cam
egr/air delete
MSD wires
Dr. Gas X pipe
QA1 rear shocks
Subframe connectors
3400# race weight
best time so far
da 144ft 54deg
1.53 60ft
7.07 1/8th
96.19 mph
11.10 et
120.45 mph
da 1479ft 70deg
1.52 60ft
7.10 1/8th
95.32 mph
11.16 et
119.63 mph
wanting to go 10.99
we have almost the same set up. best time was a 11.2 with my seventeen old son driving for the first time. I would like to get the car to 10.99.
https://ls1tech.com/forums/11-second...-time-11s.html
Old Aug 27, 2014 | 08:21 AM
Riddle0288's Avatar
2002 NBM 1le z28 a4
hardtop 22k+ miles
trans cooler
HD2 shift kit
233/236 custom cam
egr/air delete
MSD wires
Dr. Gas X pipe
QA1 rear shocks
Subframe connectors
3400# race weight
best time so far
da 144ft 54deg
1.53 60ft
7.07 1/8th
96.19 mph
11.10 et
120.45 mph
da 1479ft 70deg
1.52 60ft
7.10 1/8th
95.32 mph
11.16 et
119.63 mph
wanting to go 10.99
Try putting some air into ur drag bags.. it says u never use them?? or take ur exhaust off lol more hp with open headers an less weight lol
Old Aug 27, 2014 | 10:40 AM
021le's Avatar
What psi do i put in the rear air bags?
also what shocks setting do you guys use?
I have the fronts at full loose, and the rears 6 clicks from full loose.
def helped 60 ft going from 10 to 6 clicks in the rears.
Old Aug 28, 2014 | 04:51 AM
Riddle0288's Avatar
I run 18 to 25 psi in my air bags but my car is a 6 speed an do 2500k clutch dumps off the line tho.. so bags help my 60's to 2.2~2.0 down to 1.5~1.8's.. but being a auto u might want the rear a lil soft for weight transfer.. idk just need to play with them. But ur so close 10.99 it could just take some good cool air an a lucky day fo get there.. lol good luck my friend
Old Aug 28, 2014 | 07:34 AM
snipescastle2's Avatar
Talking camaro/firebird rear disc....
here is the parts I am looking for......
Thanks!
Ben
http://www.carcraft.com/techarticles.../photo_03.html
