In the 11s with stock ls1 engine
Full suspension except tubular k member
Viking coilovers
S60 with 4.10s
Wilwoods all 4 wheels
Draglite wheels
Et streets
Performabuilt level 2
FTI 4k stall single disk lockup
Kooks headers and true duals
SLP cold air kit
Frost mail order
Cam, intake, heads, and nitrous coming soon.
even more impressive very few bolt ons and a heavy rear end , a lot of stock internals 11 sec cars have more bolt ons and are stalled a4 cars on 10 bolts- you could definitely go much deeper in the 11's without opening up the engine.
I was very happy with my 60 ft. I played around with the front shock settings a little to get in the 1.5s. Those Vikings really do work!
The 321/331 was with the Kooks exhaust and slp cai, so I've done nothing to the engine, only drivetrain and suspension upgrades. The frost tunes runs a ton better than the old tune but I know I lost some rwhp with the S60 and stall.
2000 camaro z28 a4 arh lt magnaflow quad tips slp lid, fast 92 intake,tb nitto drag 16" tires(need more traction).
I had lca's, weld in sfc's, panhard bar, and the same power. And went 12.89 at 108 with stock converter and tires.
Then with adj torque arm, torque relocation, et streets and the trans with stall and went 12.29 at 109. Still 2.73s.
Then the rear end, vikings, anti roll bar, wilwood on all 4s, front tubular control arms, and draglites I hit the 11s. I'll be going back soon because I can do better by calming down the front end.
