11sec or 10sec?
heres the car and mods im an aussie so you have probably never heard of the car1976 holden lx ss torana 2dr hatchback (a very light 2800lbs WITH DRIVER) standard bottom end LS1, stage 2 LS6 patriot heads hand finished (flow 321cfm@.600'') comp cams 228-230@.50 dur .571''-.573'' lift 112 lobe sep, 1.75:1 rockers, LS6 manifold, 80mm BBK throttle body, 25% undrdriven pulley, double row timing chain, full custom mafless tune, custom 1.75'' extractors, twin 3'' mandrel bent exhaust with x pipe and no cats, spitfire plugs and leads and a k&n pod filter transmision is a stage 3 kitted turbo 400 with a 3200rpm stall converter and the diff is a ford 9 inch with 3.89 LSD (take into acount this car has no power steering pump or air con compresser to run) im very eager just to have an aprox 1/4 mile and hp rating
