11's for my project? Ok, I hate at add to the ridiculous amoutn of, "will I run..." threads...but here it goes. Car is a 98 hardtop (former V6 car), Power windows,door locks, and driver seat are the only option. No rear defroster,etc Its goin to have 03 Z06 Heads, Pred-Z's 230/230 cam, LT's, lid,Ls6 intake, dumper y-pipe, SD tune from DOC, Edlebrock TQ arm,and a 4k stall w/ a built trans, 3.08 gears. (More suspension pieces to come) With a 16in MT drag radial..do mid 11's sound doable? Hell are 12's possible w/ a street tire? I know its all about 60' times. But is it possible w/ the stock LCA's and such? Or should I probably do adjustable,s and a PHB? Also..is there a slight chance w/ a good 60' time and a 150 of the sauce I can brush 10's? IIRC, another guy w/ this same cam ran 11.2's?? |
low low 12's are maybe high 11's on motor with dr's |
Originally Posted by orangefun
(Post 9630334)
low low 12's are maybe high 11's on motor with dr's Or need more suspension? |
gears |
(Post 9631779)
gears Gears arn't really needed when you have a 4K stall. I'll gain what .1-.3 maybe? (just goin by other peoples results) |
I run 12.2@112 with 224 comp cam .581/.581 and 3000 stall... 275/60R15 M/T DR... only a 3.36 rear gear... th350 no headers... 2.5 true duals... no x or h pipe 3175lbs w/o driver I plan on headers... heads... and running 11.6s 11.5s spray to mid low tens... BTW...it is a Carbed Ls1 |
Sorry, i don't think some of these guys know what they are talking about. A good, high stall basically eliminates the need for gears. They aren't needed as much. I know this from experience. That predator "el torro" cam is pretty impressive i hear. I know this thread is a little old, but I have no problem seeing your running mid 11s depending on your tire and 60 ft. Let me know what you ran... |
| All times are GMT -5. The time now is 08:23 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
