11 Second Club Snake eyes are a good thing
11's for my project?
Old Jun 23, 2008 | 10:08 PM
Pro52R's Avatar
Default 11's for my project?
Ok,
I hate at add to the ridiculous amoutn of, "will I run..." threads...but here it goes.
Car is a 98 hardtop (former V6 car), Power windows,door locks, and driver seat are the only option. No rear defroster,etc
Its goin to have 03 Z06 Heads, Pred-Z's 230/230 cam, LT's, lid,Ls6 intake, dumper y-pipe, SD tune from DOC, Edlebrock TQ arm,and a 4k stall w/ a built trans, 3.08 gears. (More suspension pieces to come)
With a 16in MT drag radial..do mid 11's sound doable? Hell are 12's possible w/ a street tire?
I know its all about 60' times. But is it possible w/ the stock LCA's and such? Or should I probably do adjustable,s and a PHB?
Also..is there a slight chance w/ a good 60' time and a 150 of the sauce I can brush 10's?
IIRC, another guy w/ this same cam ran 11.2's??
Old Jun 26, 2008 | 12:41 PM
orangefun's Avatar
low low 12's are maybe high 11's on motor with dr's
Old Jun 26, 2008 | 03:55 PM
Pro52R's Avatar
Not enough power for mid 11's?
Or need more suspension?
Old Jun 26, 2008 | 04:41 PM
orangefun's Avatar
gears
Old Jun 27, 2008 | 01:54 AM
Pro52R's Avatar
gears
No,
Gears arn't really needed when you have a 4K stall.
I'll gain what .1-.3 maybe? (just goin by other peoples results)
Old Jul 2, 2008 | 01:58 PM
holley505's Avatar
I run 12.2@112 with 224 comp cam .581/.581 and 3000 stall... 275/60R15 M/T DR... only a 3.36 rear gear... th350
no headers... 2.5 true duals... no x or h pipe 3175lbs w/o driver
I plan on headers... heads... and running 11.6s 11.5s
spray to mid low tens...
BTW...it is a Carbed Ls1
Old Nov 25, 2008 | 01:24 PM
allbaugh_04's Avatar
Sorry, i don't think some of these guys know what they are talking about. A good, high stall basically eliminates the need for gears. They aren't needed as much. I know this from experience.
That predator "el torro" cam is pretty impressive i hear. I know this thread is a little old, but I have no problem seeing your running mid 11s depending on your tire and 60 ft.
Let me know what you ran...
