12 Second Club In the 12s yet? Come inside!
what should i expect
Old Feb 1, 2009 | 01:59 PM
TangeliciousSS's Avatar
Default what should i expect
my 1999 ss automatic ran a 13.111 at 107 with long tube headers a flowmaster catback and a tune with kumo street tires now i have 373 motive gears flowmaster 1 chamber turndowns under the front seats and about to get some drag radials what do yall think i will run
Old Feb 1, 2009 | 02:02 PM
lemons12's Avatar
mid 12s.. you lost some weight and gained some power changing the exhaust up..
i dont know what your 60 foot was on the 13.1111 run, so i dont know if that will improve much.. i dont know why peopl give track times without a sixty..
your gears are going to help you with a tenth probably, you came from 323s, so not a huge performance increase there...
do all the free mods, take out all the weight you can/want to... remove you filter when you go.. drop PSI to about 18 on radials..
Old Feb 1, 2009 | 02:07 PM
60 foot was a 1.96 i have a friend with a lt1 trans am with 323 gears that went from a 14.1 to a 13.80 when he installed the 373 gears
Old Feb 1, 2009 | 02:21 PM
I was hoping for a 12.7 or 12.8 maybe it will do a little better i dont know
Old Feb 1, 2009 | 04:35 PM
lemons12's Avatar
your sixty will probably drop to a low 1.9 high 1.8... just dont under pressure the tires... drop just enough to where you dead hook NO LESS..
i would say a 12.6 would be very doable... but you will probably see about a 12.7-12.8..
Old Feb 1, 2009 | 10:28 PM
CamaroRacing12's Avatar
