12's Finally!!!!!
So i finally broke into the 12's last night. My previous best was a 13.1 @ 107 mph with the mods in my sig. (minus the stall). The only changes I made were the addition of the Yank SS 3600 and a little AFR tuning before I went to the track. My race weight was 3485. The DA was around 2300. I spun off the line pretty good. I'm still trying to get the whole burn-out process down pat to heat the Nittos up good. So there is definately some left in her. I'm also pulling a little bit of timing on the top end of the track so I need to get that figured out. I think with a UDP, Tuning, an X-pipe setup, 3.73 gears, and some good air I might be able to squeeze into the 11's (or atleast get very close) w/ stock internals. I got 2 runs in last night but the second run was an epic failure so I won't go into that, but here's what my first run looked like:
60'- 1.835
1/8- 7.967
MPH- 88.19
1/4- 12.431
MPH- 110.32
My scanner is currently not working but i hope to be able to post my slip soon....
