12.34 @ 109
BLOCK: LT1 4-Bolt Splayed Mains
COMPRESSION RATIO: 8.6:1
HEADS: Ported LT1 Iron Heads, 60cc Chamber
CAM: CompCams
ROCKERS ARMS: CompCams Pro Magnum 1.6 Ratio
PISTONS: Diamond Pistons
CRANKSHAFT: Eagle 3.75
RODS: Eagle H-Beam 5.7
INTAKE: Ported LT1
THROTTLE BODY: AS&M 58mm
FUEL INJECTORS: 42# Green Tops
EXHAUST: None
TRANSMISSION: TH400
TORQUE CONVERTOR: ATI-408930
DRIVESHAFT: PST 4″ Aluminum
REAREND: GM 10 Bolt, 4.10 gears
BRAKES: Front Wilwood, Stock
WHEELS: Stock SS, custom widen steel
TIRES: Kumo SPT 255/50R17, 28″ Hoosiers
FUEL OCTANE: 93
BEST ET /MPH: 12.34/109.9
BEST 60 FT. TIME: 1.68
RACE WEIGHT: 3860 LBS
