12 Second Club In the 12s yet? Come inside!
Old Dec 7, 2004 | 07:28 AM
ruck98's Avatar
Default 12 Second Club
I AM CURRENTLY RUNNING 13:73 @98MPH RIGHT NOW I AM ON A TIGHT BUDGET AND I WANT TO KNOW WHAT COULD I DO TO GET INTO THE HIGH 12s ALL MOTOR BY NEXT SPRING
Old Dec 7, 2004 | 08:30 AM
Tom the roofer's Avatar
Converter and sticky tires what is your 60' time?
Old Dec 7, 2004 | 11:20 AM
blkZ28spt's Avatar
What 60'? What gear ratio? 2.73 or 3.23?Converter and sticky tires are a given for making an auto quick, start there. You might also need a couple simple bolt ons. Lid, CAI, ported throttle body........ What was the weather like? Your MPH is a little low.
How tight of a budget? If you are ~0.7 away you may not be able to make it without spending a little bit of money.
In short, try Nittos, ~3500 stall converter, and a lid. (converter will not be cheap to do properly, could easiler be $1k, depending on who installs it and what brand you get, etc)
Edit: i just realized you list ported and polished MAF? Who did the MAF? The only thing I know about messing with the MAF is that it can mess things up and for the most part it should be left alone.
Old Dec 11, 2004 | 02:07 PM
BIG RED's Avatar
im with the roofer...
