12 Second Club In the 12s yet? Come inside!
Opinions
Old Jan 2, 2005 | 10:31 PM
00chevyZ's Avatar
Default Opinions
my first time at the track!!!
Here are my times
13.8@107, 13.7@108 both had 2.2 60ft times.
I have been looking around and people with this mph is running much better times. any tips guys for next time.
(This was before my gutted catts, if that even helped)
Thanks
Ryan
Old Jan 3, 2005 | 06:43 PM
BTLFEDSS's Avatar
Is your car a m6 or a4 i was running around the same my first time out in my m6 car all stock i think maybe with aloudmouth cat back can't realy remember but other than that stock down to the filter.I would say you just need some more seat time the more you do it the better you get
BTLFEDSS
Old Jan 3, 2005 | 11:01 PM
00chevyZ's Avatar
my car is an m6, my main issue is launcing the car. I cant really launch above 1700 rpm without spinning the tires real bad. Also when i shift to second gear, the car fishtales and I have to leave off. Maybe I better buy a new set of tires......
Old Jan 5, 2005 | 12:20 PM
jwitt2's Avatar
Drag radials are your friend ...
Micky thompson DR's are the best out there right now
get them on take it to the track and heat them up a little (nice 4-6 sec power brake) then take the rpm's up to about 3 grand to start and see what happens. if the hook take the rpms higher. if you spin take them down a little untill you don't spin off the line.
Old Jan 5, 2005 | 12:21 PM
jwitt2's Avatar
that should drop you into the 12's easy
Old Jan 6, 2005 | 05:49 PM
Tom the roofer's Avatar
get some drag radials
Old Jan 6, 2005 | 07:19 PM
Coach 02 A3 Z/28's Avatar
"The Drag Racing Director"
Ditto!
Coach
Old Jan 6, 2005 | 09:35 PM
Mazzenger's Avatar
Traction-sounds like you need some.
A buddy of mine ran a 12.85 @ 108 with his
old 02 M6. He had a Lid and Nitto DR 275/40/17 all else stock.
Old Jan 7, 2005 | 12:26 AM
00chevyZ's Avatar
thanks alot guys for your help
