Finally made it to the track
12.52@113mph. '
Midnights, so no 60' only clocks. I bogged it really bad though. Probably not under 2.0
Anyway something is wrong because on the first two runs the clutch stuck to the floor and then the 12.52 i had to shift it realllllly slow into 4th. But hey I'm happy. Now someone tell me do I need the drill mod? Do I need to zip tie the line between the master and slave away from the headers or do I need a new master/slave? The clutch appears to be holding, albeit not for long.
EDIT : No spray numbers, kit still sitting in my garage.
EDIT : Also, according to a gear calc I found online with my 6600 rpm limiter 3rd goes to 114, so maybe I shouldn't have shifted.
