12 Second Club In the 12s yet? Come inside!
12.88 to ??
Old Aug 3, 2005 | 10:52 PM
dlovesfuel's Avatar
Default 12.88 to ??
heys guys, I am the new owner of a 2001 z28 with 33k miles and this my first post on this website. This is a awesome website and i thank all you guys for the time you put in it. Well my question is this. My z is running a 12.88 at 109 with a 1.98 60 ft right now on nitto drs. this car was completely stripped from the factory just like a 1le but obviously they didnt make actual 1les in 01. This car has a full slp intake a hooker cat back and alot of suspension mods from bmr, aluminum shaft a underdrive slp pulley, 160 thermostat, 15 pound rims. it still has a real low rear like a 2.72 or something. My question is this. I bought a set of ls6 heads and a comp .566/.275 cam. I want to install these and a set of long tube hooker headers a larger throttle body, a b&m 2 stage converter, a 3.42 rear, a programmer and a 100 shot. do you guys think this car will turn low 11s with that setup. also when we do the cam should i lifters and a double roller timing chain?? any other mods you guys would do when this car is torn down or any recommendations on parts to use. Thanks alot i am new to the modern tech so i can use all the help i can get.
Old Aug 4, 2005 | 12:09 AM
UL LOSE's Avatar
Racer
I would upgrade the valvetrain,double roller,lifters,port the TB(instead of buying one,same gain),port the intake to match heads and heads to match headers. This will make a huge difference. It will flow like no other. I prefer a lower gear than a 3.42. I would do at least 3.73s. I have 4.10s in my daily driver and i love them. Do at least a 3200stall. I dont know what size you had in mind? Make sure you get a cooler though. Low 11s should be no problem if you can get it to hook. Shouldnt be a problem to run 11s n/a actually. You should be thinking about a 12 bolt or 9 inch too. Maybe some tranny work too. Maybe im going too far with it. Hope i was of help.
