13's on Nitrous
only mods are lid,bellow,filter,borla exhaust w/o plate, and nitto D/R's.
my best time N/A was
60' 2.146
1/4 13.878
mph 102.61
nitrous jetted at 75 hp shooting from first gear up at 3000rpm and shutting off at 5200rpm manualy.
60' 2.164
1/4 13.218
mph 109.75
60' 2.155
1/4 13.180
mph 109.71
my buddy with a 01 ws6 full weight & 290 lb driver,mods slp flo pac, ported TB, and cut out, on street tires got a best of 13.4 @ 103. and it was his first time at the track.
afterwards we did a N/A street run 1 passanger in his car, and i would beat him.
Whats going on?
Parting words of wisdom--Tune, tune , tune!!!!!!!!!!! Helps to make the mods work better together.
Even though your running 100 shot kit some kits are rated at the flywheel so you may only be 80hp at the rear wheels. This should drop you .8 of a second.
Get that 60 below 2 seconds and you will hit high 12's.
Do a search on launching the car, I flash mine because of the stall.
Before I had a stall I preloaded the TC as much as I could while holding it hard on the brakes with my left foot.
Look at the tires pressures in the Nitos guys run on here.
Are you using a window switch for your nitrous?
As I and others have said it's the 60ft time that's killing the times!
He just needs to work on the launch!
