12 Second Club In the 12s yet? Come inside!
ran the car
Old Jun 16, 2007 | 06:38 PM
Ruckus46Gt's Avatar
Default ran the car
took the car to the track last night and ran a 13.5@100.7. Da was well over 4000. Corrected i was in the high 12.7 low 12.8 area. guess i cant complain for the first time out. Best 60' i got was a 1.95 with nitto drags these things stink. Couldnt stall the car above 1200 without spinning bad. You think the low mph was heat (upper 90s) or bad cat(3rd or 4th time i threw a bad cat code but it stopped rattling so cleared the code seeing if it was just a fluke that i heard a noise and that the highflow cats threw a code for me)
slip
1.956
5.619
8.658
81.497
11.205
13.515
100.743
mods
tpis lts, catted y, slp dual dual catback, grantelli maf, coolant bypass, slp smooth bellows, pro torque 3000 stall, nitto 275/40/17 drag radial, full weight nothing removed 3/4 tank of gas.
Need to get this thing into the 12s without correction
Old Jun 16, 2007 | 06:51 PM
5_02ls1's Avatar
your in the same boat as me ....shitty d/a....looks like the mph and et wouldve been a little better with that 60ft....
Old Jun 16, 2007 | 06:52 PM
5_02ls1's Avatar
has the car been tuned?????
and what gears are you runnin??
Old Jun 16, 2007 | 06:54 PM
Ruckus46Gt's Avatar
stock gears and just a crappy hypertech tune
Old Jun 16, 2007 | 06:57 PM
5_02ls1's Avatar
your not supposed to use the hypertech tune with anything more than a catback....thats more than likely the problem....i have one i use to set my fans and shift points....the stock gears are probably holdin back as well....
still not bad for high d/a
Old Jun 17, 2007 | 07:55 AM
Duffster's Avatar
your car DIED after the 1/8th... For the list of stuff there, upto the 1/8th, your good. Wish I had those #s
Duff
Old Jun 17, 2007 | 02:16 PM
Ruckus46Gt's Avatar
Duff
died probely cause of a bad cat i guess. I ran someone from a roll yesterday and well a 98 cobra should have given me such a run even though i was in overdrive. Only pulled away 3/4 of a car
