first time at the track. 12.60 @115mph
1/4 12.60
60' 2.1 launched @3k spun until 3rd (no burnout)
mph 115.4
GTP stage 2 heads ported&polished, competition valve job
GTP custom springs ,titamium retainers, locks and ferrera valves
Comp cams 228/228 duration cam .588/.588 lift 110 lsa.
Comp hardened pushrods.
SLP high flow air lid
Slp highflow bellows
ported throttlebody
LS6 intake manifold
QTP 1.75in. headers
QTP electric cutout
Qtp y-pipe
Magnaflow catback exhaust
Spohn panhard bar
Spohn lower control arms
Spohnbody mount torque arm w/ drineshaft loop
spohn sub-frame connectors
Spohn 35mm rear swaybar
Mcleod clutch
Mcleod adjustable master cylinder
Mcleod flywheel
Custom 3in. steel driveshaft
Strange engineering 12 bolt rear fully assembled and dyno tested rear end, 33 spline s/t axles, 1/2in. studs, 4.10 gears c-clip eliminators
Brembo discs on all 4 corners with hawk hps pads
racetronix intank fuel pump ractronix injectors
B&M ripper shifter
oh I ran the car on MT et street radials 275/40R17 w/ 25psi
