which engine will spin easier? with the shorter stroke? or with the longer stroke?
now i'm not sure on which heads and intake manifold to go with :
either the TFS 235cc and Fast 92mm intake manifold or the GM LS7 heads and LS7 intake manifold?
Ron@Vengeance said they obtained more power on 427ci and 440ci from TFS 235cc heads and Fast 92mm intake manifold more than the GM LS7 heads and GM LS7 intake manifold.
note that the CNC TFS 235cc heads flow 344cfm with a much smaller port 235cc and smaller valve 2.08 smaller than LS7 heads where the GM LS7 heads flow around 360cfm with a bigger port 255cc intake runner and big intake valve 2.20.
note that i like small efficient ports that flow good over huge ports that flow big numbers. i like port velocity much more than flow numbers.
i'm realy confused which heads to go with for a 440ci stroker, hand touched up CNC TFS 235cc or hand touched up GM LS7 heads?
Your port size arguement goes out the window becasue of different valve angles. Apples, oranges comparison.
How exactly do you measure the velocity in a running engine...........
first cross sectional area.
second port runner volume.
third valve angle.
here is a "basics to engine design" which may clear up some confusion
Power is the result of extracting the chemical energy from the fuel. More Power is a results of More fuel being burned and using that heat energy more efficiently. (also, torque doesnt mean much.. power is important)
Because we are talking about Naturally aspirated Spark Ignition Gasoline engines, the air-fuel ratio lies within a narrow range. For simplicity sake, we'll assume a constant Air-fuel ratio.. This means that we need to add air at a porportional rate to fuel..
Whats the limitation? Well we all know you can get bigger injectors and bigger fuel pumps.. so we arent limited in fuel supply. However, a natually aspirated engine is limited into how much airflow it can ingest. This means that our focus to maximize power would be to maximize airflow!
To accomplish this, there are only 2 basic options. RPM or displacement(note i did not say increase stroke or bore specifically). At the end of the day, MASS AIRFLOW is the name of the game.
I'll discuss RPM first.. because of the fixed displacement of the engine it can only ingest so much air per revolution. Therefore, to make more power, you would want to spin the engine faster. You quickly run into limitations once you start pushing the RPM higher in your car, such as; valvetrian staibility, rotating assembly strength/balance, cylinder head flow, valve size.. etc
Due to the limitations that show up with RPM, you can also increase displacement to increase airflow per revolution, (i.e. torque). This can be accomplished by increasing bore or stroke... or both. One or the other, in its own right, does not increase torque more than the other. Displacement is what makes torque!
Having large stroke and small bore will run into rpm limitations with the rotating assembly and valve size (smaller bore only allows for small valves) Airflow restriction typically increases dramatically on these configurations as rpm goes up.. thus they are known as "low rpm torque monsters" because they die at high rpm because of the valvetrain/cylinderhead airflow restrictions
Having a large bore and short stroke can run into mixture motion issues, valvetrain stability issues, etc.. But you can have very large valves in relation to displacement. If you have a given displacement, going this route will assist in higher rpm operation (i.e. forumula 1).
at the end of the day, there are tradeoffs for all designs.. far to many to list here.
and just think this is my 2nd postNice concept but when executed it does not work. A heavy flywheel is the old school way of shocking the tires harder. once engaged, you will make more torque/hp because of the reduced rotating mass, but you should gain both.
Nice try for the 2nd post though. Just please try to refrain from being cocky on here.
and just think this is my 2nd postThis I think is a good example of how your idea doesn't effect the torque produced at the flywheel but it does increase the torque number at the tires. The torque output of the engine is largely effected my the stroke of the crankshaft not the flywheel bolted to it.
